2002 2wd front end lift question???
Old Apr 6, 2012 | 3:31 PM
smokeater347's Avatar
Default 2002 2wd front end lift question???
Hey all,
in my possession I have a 2" coil spacer leveling kit for my truck. After It has been installed my truck will be level. I want to go further and add another 2-3" without having to mess with spindles, control arms, etc, etc. If i can accomplish this ill add blocks and u-bolts in the rear to gain a level 2-3" lift all around.
the truck is a 2WD 2002 silverado 1500. How can I add a couple more inches up front after the leveling kit is in place without a full suspension lift kit(budget issues......)
Old Apr 6, 2012 | 4:11 PM
country_09's Avatar
Spindles are cheap, those would be the best bet honestly...without goin either spindles or full suspension lift that leaves you with a body lift.
What I'd do, is do a 3" spindle lift, 3" block out back then add a 1.5" body lift on top of it. All in all about 400 if you can find a deal on the spindles, if not then about 500(200 for body lift and 300 for spindle lift). Blocks are cheap so I didn't include those
Old Apr 9, 2012 | 7:20 AM
ok thanks. any suggestions on where to get spindles? only ones i have found are upwards of $400-500. thats a bit more than i want to put into a 2wd truck
Old Apr 9, 2012 | 4:26 PM
country_09's Avatar
Check out eBay...they'll have em in the 300 dollar range. Still not cheap but better than the 400-500 dollar range for the same thing
Allans454
Nov 20, 2012 5:22 AM
Rlock4227
Feb 19, 2012 11:26 AM
bjf1280
Jan 29, 2012 2:24 PM
Badland
Mar 23, 2008 2:10 PM
guitarhero
Jan 5, 2008 11:44 PM
