2002 chevy k 1500
Old Jan 29, 2014 | 4:41 PM
ryito1122334455's Avatar
Default 2002 chevy k 1500
h have 127,000 mikes on it, and under load it shifts funny, sometime it does it empty also....not a slipping but more of a hard shift?...tow/haul mode it does it as well as regular mode.....should i change my tranny fluid/filter? no check engine light is on, and it only does it sometimes....had the truck just under a year ...fluid looks clean and dosent smell burnt, any advice?
Old Mar 1, 2014 | 3:26 PM
bump....anyone??
Old Mar 1, 2014 | 4:14 PM
Allan In NE's Avatar
That's what it is supposed to do. The heavier the load, the "harsher" it will feel. This is totally normal.
Allan
Old Mar 1, 2014 | 8:21 PM
'03 Heavy Chevy's Avatar
Allan is correct.
It wouldn't hurt to drain the fluid, drop the pan and change the filter.
Are you the original owner? If not or more than 50k miles since you last changed the transmission fluid / filter......then i'd do it.
DUH!!!! I just re read your post......lol do you know the last time (mileage or time frame) the trans fluid / filter was changed? If not then change it so you know for sure.
Danistheman1234
Mar 7, 2021 10:20 PM
redbone
Oct 16, 2009 11:16 AM
roaddog6512
Feb 25, 2009 5:28 PM
chevyshane
Aug 10, 2008 7:38 PM
