2002 Silverado Reversed defrost & front air
Old Dec 23, 2013 | 4:18 PM
Dbuseyiii's Avatar
Default 2002 Silverado Reversed defrost & front air
I replaced the mode door actuator and it has full range of motion but the bottom air does not work at all and the defrost and front air are reversed. Any help would be greatly appreciated.
Old Dec 23, 2013 | 4:29 PM
Welcome to the forum....
I suspect that the actuator was place back on in a default position that was different from what your system was set in...
Old Dec 23, 2013 | 4:56 PM
Dbuseyiii's Avatar
Thank you for the response. I suspect something similar. Do you know how to fix this because the actuator can only go in one way and then the recalibration is supposed to correct it. I have followed the instructions for recalibrating without a scan tool with no luck.
Old Dec 23, 2013 | 5:25 PM
I have not replaced one so I am not totally familiar with the unit, but what I would try is to put the system in a known position to you, i.e. defrost, remove the actuator, leave it hooked up electrically and then set to to the position of last known... that should put the motor in the right position to match up with what it was in when you removed the actuator....
Old Jan 7, 2014 | 11:17 AM
twoblacklabs's Avatar
Unhappy I'm in same boat
Have you figured this out? I am in the exact same situation. Any help will be appreciated.
Old Sep 20, 2021 | 9:26 AM
jensenracing77@yahoo.com's Avatar
I am having this same problem. Anyone know what to do about it? The calibration mode will not happen on this truck. 2002 2500 HD
coling659
Oct 14, 2013 9:17 PM
hub_cap
Apr 8, 2013 6:49 PM
jimmys57chevy
Aug 22, 2012 8:45 PM
shadowrider05
Aug 15, 2012 1:11 PM
