2002 Z71 Fuel Line
Old Nov 18, 2013 | 12:52 PM
jjrmissions's Avatar
Default 2002 Z71 Fuel Line
What would cause my truck to turnover repeatedly before starting? I replaced the fuel filter, and a cracked fuel line coming off the fuel rail on the driver side. Is it possible that the pcv valve would have anything to do with this issue?
Old Nov 18, 2013 | 4:04 PM
RAUTOFIX's Avatar
No. Did this problem start after you changed the filter or was the condition there prior to the filter swap?
Old Nov 19, 2013 | 9:51 AM
ToooTall1's Avatar
Default Starting
Turn the key on and wait a few seconds then do it again and then try to start the truck. If it starts like normal then you are losing fuel rail pressure. Causes may be a fuel pump going bad, fuel pressure valve on rail or a small leak. I have three Silverados and have replaced the pump on two with a good brand ( no chinese crap) and it has solve my starting problems
janderson6791
Jul 23, 2020 8:25 AM
NMguy
Jan 28, 2012 12:16 AM
tom5170
Apr 17, 2010 3:10 PM
perlgoodies
May 21, 2007 10:46 PM
dogz46
Nov 25, 2006 8:44 PM
