2003 1500 - O2 sensor
Old Mar 20, 2009 | 12:08 PM
JoeCB's Avatar
Default 2003 1500 - O2 sensor
Hi, got an service engine light on my 03' Avalanche and scanned code PO141... O2 sensor heater circuit Bank 1 Sensor 2.
I bought the new sensor, can you tell me where the Bank 1 Sensor 2 is physically located? I know that there are several under there.
Also do I need to do anything to reset the read out after changing the sensor?
Thanks
Joe B
Old Mar 23, 2009 | 9:59 AM
JoeCB's Avatar
Default O2 sensor
Well, it looks like I have to answer my own question... may be of help to someone else with this problem.
After doing some research I found the answer and fixed the problem. My 03' Avelanch has four O2 sensors, two on each engine bank, one ahead of the cat and one after. So, the bank 1 sensor 2 is located on the #1 (left) engine bank after the cat. And the sensor turned out NOT to be the problem, I had a broken wire in the harnes going to the sensor heater circuit. ie. no 12 VDC to the sensor.
Joe B
ldearman
May 5, 2011 4:08 PM
gossimer
Nov 12, 2010 4:47 PM
vBruce
Jun 10, 2010 7:40 AM
jffgin
Mar 10, 2008 2:32 PM
