2003 Silverado Brake Problem
Old Jul 21, 2007 | 9:12 AM
mit's Avatar
mit
Default 2003 Silverado Brake Problem
Theinside of the rear brake rotorson my 2003 Silverado are rusted and corroded. The inside rear brake pad is also wore out. The truck only has 40,000 miles on it and I was wondering if thisis a common problem and why this happened.
Old Jul 21, 2007 | 11:06 AM
ZX1100F1's Avatar
Default RE: 2003 Silverado Brake Problem
mit, do you live or drive in a state that uses salt to clear ice and snow from the roads?
Old Jul 21, 2007 | 12:19 PM
mit's Avatar
mit
No. The rotor is also only corroded onthe inner sideand only the rear rotors are corroded.
Old Jul 22, 2007 | 3:59 PM
kcb37's Avatar
If you look at your calipers they only have one piston, on the inside (or towards the diff). When you hit the brakes that pad hits first then the caliper slides over and the other pad contacts the rotor. Most of the time that is why one pad always wears faster then the other. As for the corrosion it could be from water or something you drove through. If it is only on the rotors I wouldn't worry about it. You will have to replace them eventually anyway.
Mark_MS
Jan 29, 2018 7:10 PM
Mark_MS
May 16, 2015 1:12 PM
dh0765
Mar 30, 2010 10:08 PM
tom5170
Mar 19, 2010 11:57 PM
harleyspider73
Nov 28, 2009 6:30 AM
