2004 cheby silverado 1/2t 4x4
2004 cheby silverado 1/2t 4x4 Dash Cluster help
the problem i am having is that the tach and speedometer will stop working while i am driving it. it happen early this year during the summer time when i left it idle for a extended amount of time, like 45 to an hr cause my gf hit a deer with her car..
but when it happen that time i end up just pulling over and turn the truck off for a few minutes then restarted the truck and both started to work again. very odd but i never knew what caused it and still dont.
this dash does have a few problems something that bocker chevrolet in freeport illinios wont even fix unless i pay for it, which i dont think i chould cause they never did before i bought it from them. beside they never detailed it before i got, i had to clean it up my self.
this truck has been nothing but a nightmare and a gas hog to boot. with alot of electronic problems to only getting 10mpg nio matter how/where i drive. or more like the lack of driving i do, i average like 5k miles per yr..
but is the dash covered for somethikng like this from chevy? bad enough i cant even do a full tune on it since the fuel filter is part of the fuel pump.. gawd who ever thought that was a good idea needs a 20lbs hammer to the head...
uhm 182 view and no one knows or why this desh does this? i havent drove my truck yet so i dont even know if the tach and speedometer are working or not. but i did forget to mention that for the 1st time since i test drove this truck and owned it, i got to see what the gear selector looks like. i do mean the 1st time i saw what gear i was in and it was nice but not knowing how fast i was going suck but glad i just kept up with traffic
232 views ??
well started it today and went to the doc and my tach and speedo are working . very weird. wonder if replacing the dash cluster would fix this beside the other problems i am having with the gauges. but it isnt cheap so it will take me a few month to save up since the dealer want $255 for it..
well the speedometer is barley working now but so far the tach is still so i have an idea of how fast i am going. just wondering if and when i get enough cash to buy a new cluster if it will fix these problems?
[QUOTE=JPS69OLDS;292428
but is the dash covered for somethikng like this from chevy? bad enough i cant even do a full tune on it since the fuel filter is part of the fuel pump.. gawd who ever thought that was a good idea needs a 20lbs hammer to the head...[/QUOTE]
The clusters had a special coverage but you are well past that at this point.
How would changing a fuel filter improve fuel mileage?
Maybe you should do some reading on returnless fuel systems so you will understand why the filter doesn't need to be serviceable.
and yes i found out that i am past the date of having this done by GM. but i didnt buy this new i got it over used it seems. i sure miss my 96 truck a lot more now because of this truck.
in the 13yrs i had the 96 truck i had it didnt even come close to the problems i am having with this 04 truck. beside my 96 had like 70k miles less....
anyways if this dash wasnt done by gm for the recall it shouldnt have a time set to it to run out..
base idel ?
i know this is off topic, but what is the base idel in gear for my 04 1/2ton 4x4 with 5.3 ? i have looked threw the owner manual and the chilton book i have and so far i can not find it.
i ask cause my truck seem to idel way low cause the head lights and such will be dime and the volt gauge will drop down to 12/13 volts and if i turn on the rear defrost it really drops and i have replaced the alt and battery twice so far since i got this truck in 2013...
or could the dash cluster be causing this as well ?
and i dont think so? never seen those before i have been out of the auto repair for over 10yrs now since i became disabled.
