2005 chevy silverado 4wheel drive issues
Old Mar 8, 2023 | 11:06 AM
Starrslight's Avatar
Default 2005 chevy silverado 4wheel drive issues
Hello,
I was plowing with my Silverado and everything was going along fine, then the 4 wheel drive just stopped working.
It's a manual shift and I still have lights on the dash. I took the actuator out and checked it.. it works..
Any help greatly appreciated.
Old Mar 8, 2023 | 12:05 PM
Gumby22's Avatar
For a manual shift transfer case, there’s only a few possibilities if the actuator is working.
Check the front driveshaft for broken U-joints.
If OK, drain the fluids in the front differential and transfer case. Catch them in [separate] clean containers and inspect for metal particles.
SOME metal is normal (sawdust sized grains) - what you’re looking for is larger particles, about the size of splinters and larger.
Try to use a flashlight to look inside the drain plug bores and check for larger metal pieces lying in the bottom of the cases.
Bwizzle
Feb 3, 2020 6:32 PM
drrose11842403@yahoo.com
Jul 15, 2017 1:13 AM
tommyboy7328
Dec 7, 2015 12:22 PM
Walls1887
Jul 11, 2014 10:16 PM
