2006 silerado 1500 brake problems
Old Aug 25, 2014 | 1:17 AM
roadhog's Avatar
Angry 2006 silerado 1500 brake problems
have changed master cylinder,booster,brake shoes , bleed brakes but couldn't get fluid to the front brakes only the rear. also the abs light and brake light are not on any suggestions ?
Old Aug 25, 2014 | 9:32 PM
silverado 1500 2001's Avatar
well there's a hydraulic distribution box (%60 front, %30 to the rear is it?) about midway down line rarely do they ever "go bad". but it's possible.
i can't see how your lines are run so i don't know (kinda doubt) the distribution box could clog the front
maybe clogged or bent lines ?
start at master cyclinder, see it pumps fluid by hand, then that the line connected up to caliper isn't clogged, hand pump see if it comes out, finally caliper if fliud is not blocked or cyl fronzen, in it btw do your brakes "drag" on your rotor? do you wheels spin real nice and easy ? unsure if there's a horse sense way to avoid soem of that
all said and done: yup you'll probably have to bleed the breaks again at least once
abs can "be involved" but for safety reasons there si a cutout which insures if you break it cannot "block breaking" (it lets pedal pushing through if it's not working)
also break booster has outer inner part. some companies put a plastic valve INSIDE a booster vacuum line (hard to see for obvious reasons) i kinda doubt chevy does. sqeeze lines if you must
Old Aug 26, 2014 | 8:15 PM
roadhog's Avatar
Smile
thanks for the reply but I found one of the metal lines to the front brakes had a pin hole in it letting it catch air
joshuasoileau
Feb 18, 2013 7:24 PM
budbuzz350
Feb 4, 2013 7:09 PM
CaptEd
Apr 25, 2012 10:00 PM
fido00
Mar 18, 2008 11:32 AM
bluesierra
Nov 24, 2005 1:28 AM
