Old Jul 22, 2015, 1:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
2006 Silverado Z-71 upper control arm
Old Aug 6, 2013 | 9:39 PM
mibar's Avatar
Default 2006 Silverado Z-71 upper control arm
As I was changing my oil, I noticed that the bracket weld (closest to the front of truck) on the upper control arm was cracked. I don't know anything about suspension, and I am worried this can cause a major problem or can I just get it rewelded. It's the bracket that limits the control arm at the bottom. If that makes sense. I need some advice as to what to do.
Old Aug 7, 2013 | 7:12 PM
country_09's Avatar
It's the droop stop. It limits the travel so you don't busy ball joints and what not. Do you have a levelin kit or a lift kit at all? I know a lot of people cut them off cause you're usually not at risk of damaging anything unless you're dune jumpin or beatin it in every mud hole.
Old Aug 8, 2013 | 9:38 PM
mibar's Avatar
Default Thank you
I didn't know what the stops were called. I have a 2 inch leveling kit, and I took my Silverado to get aligned yesterday and the guy at the shop said that it was fine. Thank you once again.
jabba66
Jan 16, 2014 2:39 PM
00chevy1500
Nov 24, 2013 10:03 AM
jljbtm
Nov 13, 2011 7:11 AM
#1DEER1I
Apr 17, 2010 7:48 AM
maxxman04
Mar 9, 2010 5:34 PM
