2006 V6 single can. Plz tell me it’s not rebuild time.
Old Oct 9, 2023 | 11:08 PM
Shtoutaluck247's Avatar
Default 2006 V6 single can. Plz tell me it’s not rebuild time.
As of yesterday my automatic 06 1500 V6 shifts into what “feels and sounds” like neutral instead of third. I have two abs codes showing on OBS, speed sensor circuit malfunction and ABS/TCM circuit malfunction. I have no ABS or check engine light and everything else works perfectly. No sounds no grinding no slipping. Just goes straight to “neutral” any suggestions before I make a trip to rebuild would be helpful. I’m supposed to see my daughter 1.5 hrs away tomorrow night. Thank you
Old Oct 10, 2023 | 3:09 PM
Post the full code please, and your miles.
Old Oct 10, 2023 | 3:36 PM
Default Code/mileage
C 0035
C 0161
Miles: 195,2871
Old Oct 10, 2023 | 4:45 PM
so the full definition is
DTC C0161 Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch
Check to make sure the brake switch works.
https://www.autocodes.com/c0161_chevrolet.html
https://www.obd-codes.com/forums/viewtopic.php?t=16529
As for the wheel speed sensor, make sure the sensor is plugged in all the way (clicked), and the wiring isn't damaged, or corrosion in the connector. Make sure rust hasn't accumulated on the mounting surface. Replace if necessary.
Azaghal
Sep 20, 2016 11:15 PM
Oogie
Mar 26, 2014 10:18 AM
decker5484
Dec 14, 2012 9:39 AM
wmaleck
Feb 13, 2012 5:37 PM
CeS
Mar 11, 2011 5:14 PM
