2007 classic a/c won't blow
Old Jul 14, 2011 | 4:48 PM
mvaughn's Avatar
Default 2007 classic a/c won't blow
I have an early 2007 chevy classic and the a/c will not blow sometimes at other times it's works normal. The compressor always comes comes on but no air. When it's not working and you turn the fan speed **** from 4 to 5 you can hear a click that is coming from a switch below the glovebox. Any help would be appreciated!
Old Jul 15, 2011 | 3:16 PM
Official GM Rep
mvaughn,
I am sorry to hear that you are experiencing this issue. Have you had your dealership look into this issue for you?
Thank you,
Elizabeth, Chevrolet Customer Service
Old Jul 16, 2011 | 2:34 PM
kevinkpk's Avatar
If you suspect the motor, jump 12 volts to it, if it works, then it isn't the motor. If the motor does not come on, add a ground wire from frame to the motor case to cheak if grounding is an issue.
Blaidd Drwg
Nov 19, 2013 3:49 PM
Surge709
Jun 19, 2012 12:44 PM
DavidHXC
Jan 7, 2012 10:26 PM
mvaughn
Sep 10, 2011 1:38 PM
tmbeck7
Oct 18, 2010 9:31 PM
