2007 Vibration when braking goes away in neutral
Old Aug 21, 2012 | 11:57 PM
metaljames88's Avatar
Default 2007 Vibration when braking goes away in neutral
I'm new to the forum and hoping to get some help. I have a 2wd 2007 NBS 1500. The truck cab has a shimmy or vibrations when braking. At first I thought it was just the rotors. The weird thing is, if I put the truck in neutral before braking, the vibration goes away. Anyone got any ideas?
Thanks in advance,
-James
Old Aug 22, 2012 | 12:56 PM
Official GM Rep
Thanks in advance,
-James
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I'm sorry you are experiencing this issue with your vehicle. I encourage you to contact a certified technician for additional assistance. The will be able to offer more information after inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
Old Aug 22, 2012 | 1:30 PM
I guess I should add that I'm not really in position to pay for a tech to fix/diagnose this issue. I'm moderately comfortable working on cars, I'm just hoping for some guidance from people that may have experienced similar issues before I attempt of start fixing it. I get that 9/10 people would probably just take it to the dealer, but I'm a cheap s.o.b. Any other thoughts? Also, the truck has 77k miles on it. I just bought it, despite it's issues with vibration because overall it seemed to be a pretty well kept truck.
Old Aug 23, 2012 | 12:50 PM
It turns out it's probably the same thing others have complained about regarding some silverados having a rough transition from V4 to V8. When my truck gets up to v4 mode, and then I slow down, the the v8 kicks in and is particularly rough, as if I'm driving on a gravel road. I think I'm going to look into the diablo tuner and try to turn active fuel managment off. I'm kind of dissapointed, because I originally wanted this truck because of the afm feature.
bruce cairns
Sep 23, 2013 8:56 PM
rob06
Jun 29, 2013 11:23 PM
Cretaccir
Jun 13, 2013 1:00 PM
greatwhite99
Aug 27, 2011 4:00 PM
ambiguous216
Aug 2, 2011 9:09 AM
