2008 4x4 Duramax Chevy Silverado
Any warning lights or messages on the dash, such as check charging system?
If they both quit suddenly, the first things to check are:
1) The serpentine belt failed (broke) and the pump pulley isn’t spinning, which would also cause the alternator to stop charging and set the warning message/light.
2) The pressure hose burst and fluid is leaking; or it could have collapsed and is causing a restriction. Either one would likely cause pump noise.
3) An internal component to the pump failed and it needs replacement.
Dave Kennedy
November 23rd, 2015 4:43 PM
crwalker2
December 24th, 2010 5:55 PM
pipes
January 14th, 2010 2:34 PM
