2008 silverado headlight issue
Old Jan 10, 2015 | 1:03 PM
motleymike's Avatar
Default 2008 silverado headlight issue
Low beams aren't working...new bulbs...all fuses are good...any suggestions.
Old Jan 16, 2015 | 7:58 PM
ot2bnla's Avatar
I had the same thing happen to me, what I did was with the lights on pull the bulbs out and pushed them back in. I think it might of been contact issues with the new bulbs I bought. Just be forewarned wear gloves those bulbs get hot when they turn on. Not sure if this will fix your problem but it's worth checking out.
Old Jan 16, 2015 | 9:58 PM
do the dtrl run throught the low beams on your model? the z88 option does. if yes, do the dtrl work? another item to check are the dtrl relay and hdlp low/hid relay. do they click when energized? the bcm grd controls both of these relays, so if the power is present to the relays and the relays are good; make sure the bcm is providing grd to the circuit.
garyv990
Feb 11, 2015 9:52 PM
motleymike
Jan 8, 2015 11:09 AM
duckmaster1
Jun 12, 2012 6:38 PM
6t7gto
Apr 8, 2010 2:46 PM
big_stank420
Dec 19, 2006 2:56 PM
