Notices
2009 Parking lights won manually turn on
Old January 29th, 2013, 10:28 AM
MattDaddyG3's Avatar
Default 2009 Parking lights won manually turn on
Hello Folks,
Just purchased my first Chevy pickup. I remember from a 2002 Malibu i had you could manually turn on the headlights or just parking lights even if it wasn't dark enough to trigger the automatic head lights.
I can't get just the parking lights to turn on manually. When I move the switch to headlights (all the way to the right) just the headlamps turn on. No parking lights or taillights.
Auto is working just fine, when dark enough, headlights and parking lights turn on correctly. Any thoughts? Thanks!
Old January 29th, 2013, 10:51 AM
Welcome to the forum
The positions should be, Off, Auto, headlamps, parking lamps, on the dial ****.. that is how they are on my 07 Tahoe....
Here is a link to your owners manual, and a picture of the page of how to operate the head lamps
http://www.chevrolet.com/content/dam...ado_owners.pdf
Attached Thumbnails 2009 Parking lights won manually turn on-parking-lamps.jpg
Old January 29th, 2013, 11:20 AM
Thanks for your help!
I have downloaded the manual. It seems that the parking lamp position isn't functioning and the headlamp position only turns on the headlamps. No taillights.
Auto is working normally.
At night I want to be able to just turn on the parking lamps while parked. I need this for work. Thanks again!
Old January 29th, 2013, 11:21 AM
If the parking lamp position is not working, I would try removing the switch and seating the electrical connector, and if you can get the switch open maybe try cleaning it...
Old January 29th, 2013, 11:23 AM
That was my next guess. Maybe a loose or dirty connection. I did, after all, buy it used. Do you have a manual for removing the switch? LOL
Old January 29th, 2013, 11:25 AM
As a matter of fact I do... however its about 20 miles away, at home... I can look for and post it this evening....
Old January 29th, 2013, 11:30 AM
Thanks again for your help. I don't really want to just pull on it and risk breaking it.
Old January 29th, 2013, 11:35 AM
You may be able to see up under that portion of the dash, if so you may be able to see that its held in with clips and you can wiggle it straight out.
Old January 29th, 2013, 11:40 AM
Also a good plan. I will get the flashlight out. I will also take a picture if able.
Old January 29th, 2013, 12:37 PM
Ok, was able to remove the headlight switch fairly easy. Just 2 screws and a bunch of clips. the plug that plugs into the switch looks to have had something attached to it at one time using splices. Also, there is a smaller plug not plugged into anything. You'll see what I mean in the pictures.
Quick Reply: 2009 Parking lights won manually turn on
