2012 Silverado cargo lamp
Old Dec 29, 2021 | 2:26 PM
jdszable's Avatar
Default 2012 Silverado cargo lamp
May be silly sounding but, I have a question in regards to potentially wiring the cargo lamp so that it turns on when putting the vehicle in reverse? Is it even possible given that the cargo lamp is set up to turn on with the dimmer switch on the dash? It's very hard to see behind me at night. Obviously the best option would probably be installing brighter backup bulbs or maybe even an extra aftermarket setup but im trying to get creative before spending any extra cash. I do have tinted windows but there is no tint in the back window as I removed it shortly after I bought the vehicle based on the fact that I couldn't see at night when backing up. Any and all help and guidance are appreciated
Old Dec 29, 2021 | 3:37 PM
hanky's Avatar
I doubt if you would get much illumination from the cargo lamp..
What I would consider,
Install one or two small LED white lamps that would be tied into the backup light circuit. They don't pull enough power to trigger any adverse problems and will lite up all of what you need to see , plus.If carefully placed , should do the job and not get knocked off easily.
Old Dec 29, 2021 | 7:02 PM
Welcome to the forum. Moving to the Silverado section where you will get more views.
