2015 1500 electrical upgrade questions
Old Aug 26, 2025 | 9:19 AM
mlee's Avatar
Default 2015 1500 electrical upgrade questions
I plan to upgrade the alternator and add a dual battery setup to my 2015 1500 LT 5.3 (for towing/carrying an off-grid capable camper) but have encountered some issues. I need to run 2/0 AWG wiring from the second battery to the main battery, but the battery current sensor clamp, with a diameter of about 0.75 inches, currently holds two black insulated wires, making it impossible for the 2/0 cable to also fit. Is there a larger diameter battery current sensor available? will splicing the two cables currently going through the battery current sensor to the 2/0 cable work? If not, what are my other high current wiring options?
My 1500 has the OEM 150A alternator, the only GM upgrade I see is a 170A model. +20A isn't much of an upgrade. GM lists a 220A alternator (GM part # 84143539) for the 2015 2500. Will this fit in my 1500? Does anyone offer a quality aftermarket 220A - 350A alternator for my 1500?
mLee
pinoiryder
Apr 27, 2023 9:30 PM
rdrennan107
2014 - 2018 (GMT-K2)
Apr 24, 2023 8:21 PM
Rrabenold
Jan 12, 2019 5:11 PM
Rrabenold
Jan 4, 2019 8:55 AM
Blue Burb
Jul 22, 2012 8:40 PM
