2015 2500 HD Duramax Upper Control Arm Camber Bolts
Old Mar 13, 2022 | 7:32 AM
15 Duramax's Avatar
Default 2015 2500 HD Duramax Upper Control Arm Camber Bolts
I recently installed Zone upper control arms with the 3" Adventure series lift on my 2500 HD . A few weeks after install I saw a video on Youtube that spoke about blue and silver color coded camber bolts and their proper placement. I checked and did find I had blue and silver variations. At the time I thought it was blue Loctite residue. I did not pay close enough attention at the time and want to make sure I have them in the right configuration before I bring it for a front end alignment. I currently have both sides installed with the bolt heads on the inside of the shock wells and the nuts for each bolt forward and rear. As for the colors, the driver side is now blue in the rear and the passenger side is blue bolt in the front. Do I need to change anything.
Second question: Is there a tool or trick to install the small cam guide pins. These are the pins that press in and protrude throuh the cam bolt guide slot.
Thanks,
Joe
Yogi
HHR
Dec 30, 2018 9:43 PM
Martin1234
Uplander
Sep 26, 2017 10:23 AM
trainwreck91
Aug 17, 2014 6:56 AM
00chevy1500
Nov 24, 2013 10:03 AM
madmaxx1
Jul 28, 2009 3:26 PM
