2500hd rear axle seals
Old June 14th, 2010 | 8:42 PM
sledneck421's Avatar
Lightbulb 2500hd rear axle seals
I have a 03 2500hd with the 6.0 and i have changed my brakes on it for the first time with 80000 and a saw that the rear seal was leeking a little bit so i changed both of them you know murphys law if i would of just changed one. Well i have 90000 on it now and i ahve replaced the seals 3 times now since the first ones and i looked today and what do you know there all wet again on the pass side there napa seals what can i do??? i am lost i need this issue fixed
Old June 14th, 2010 | 9:06 PM
MDTAHOE's Avatar
Professional Mechanic
If the axle is worn at all it will continue to leak. Get axle saver seals. It is a bearing and seal all in one. It moves where the seal rides on the axle.
Old June 14th, 2010 | 9:23 PM
where can i get them at?? and what is weard is how do the axel shafts wear down?
Old June 14th, 2010 | 9:36 PM
MDTAHOE's Avatar
http://www.ehow.com/how_5063312_remo...ing-chevy.html
Any real parts store should have it, not Chain stores. Stores like Napa, Fisher, Olympic etc. We use a parts store called Delco Line. The have had them every time we needed them. They should be around $20
Yogi
March 7th, 2014 5:02 AM
Nat
September 8th, 2011 11:57 PM
usmarine0905
July 12th, 2010 11:16 AM
itlldue
October 22nd, 2008 10:05 PM
BCKNBLK
June 26th, 2006 12:41 PM
