Rear axle seals leaking
Old Jul 11, 2010 | 7:43 PM
usmarine0905's Avatar
Default Rear axle seals leaking
Hi, again. It's been sometime, 98 silverado, c2500, 5.7 vortec. I replaced the axle seals appx 2 months ago. I dont drive it much, but i notice now it is leaking again after a 4 hour road trip i took. What is the amount of lube to put back in the rear end when completely empty. when i did the seals last time I put 3 bottles of synsetic back in, could that be too much? and could that be why the seal are leaking, or just a bad pack of seals. I took a lot to make sure i did not nick them and the axle where smooth and clean. tks
Old Jul 11, 2010 | 8:52 PM
I don't know the answer for sure, but I thought the proper fill amount for the diffy was to fill it to the fill hole.... but lets see what some of the other responses are...
As for the continued leaking I would be suspicious of the trueness of the shafts or possibly the bearings are worn...
Old Jul 11, 2010 | 10:17 PM
thanks for ur post... i only replaced them last month cause there was a little seepage on the backing plate.....ugh.....maybe i should have left them alone. I am going to chevy and get factory seals this time
Old Jul 11, 2010 | 10:21 PM
LARIDERS's Avatar
when you fill the read diff, fill it till it starts coming out the fill hole as in2pro said. rear seals can be tricky, I have seen them leak a few times after puting in new seals. my buddy did 3 sets in a year, and now 3 years later still no leaking. They can be picky. if your towing a heavy load there is more of a chance for them to leak.
Old Jul 12, 2010 | 10:16 AM
@Lariders,, thank you for your post. I dont haul anything heavy, it's mainly my comute truck and weekend projects. I will give it another set of seals, and see what happens...
@in2pro... thanks for ur post in refilling the diffy. as u stated, fill till it starts comming out the fill hole, that is what I did, so thank you, I did not want to feel as though i put to much in...LOL...
Getting seals from Chevy this week.....
Yogi
Mar 7, 2014 4:02 AM
Nat
Sep 8, 2011 10:57 PM
sledneck421
Jun 14, 2010 8:36 PM
itlldue
Oct 22, 2008 9:05 PM
BCKNBLK
Jun 26, 2006 11:41 AM
