3.73 RATIO REAR in a 2009
Old Jan 27, 2009 | 8:01 PM
adamant's Avatar
Default 3.73 RATIO REAR in a 2009
what is the difference in a standert rear and the 3.73? will i notice a difference?
Old Jan 27, 2009 | 8:08 PM
x1cn18's Avatar
if the standard is a 342 yo will notice some difference little better take off better towing slower top speed
Old Jan 29, 2009 | 2:52 PM
therewolf's Avatar
What's "standard?" My vehicle came with 410 gears "standard". I changed back to 342s for better highway mileage, and lower RPMs. 373s are supposed to be a great compromise gear for both power and mileage.
Your window sticker should have your differential size listed, if not, the dealer should be able to tell you. If you make the change, your speedometer and ABS sensors will give false readings until you have the PCM reprogrammed with your new gear size. Find out if your mechanic is aware of this before you have any work done.
A CAI may give you the power you need at about 1/6th of the cost of a new diff set, and no internal reprogramming.
Old Jan 29, 2009 | 3:48 PM
bubba33's Avatar
What you have is all around best choice.
Old Feb 11, 2009 | 12:05 PM
J-man67's Avatar
A CAI will not help in this situation. The power gained from a CAI is high in the RPM range.
Old Feb 11, 2009 | 12:09 PM
bubba33's Avatar
Talking
You sure got a set of perty wheels on that there truck hehehe
Old Feb 11, 2009 | 12:47 PM
J-man67's Avatar
HAHA, you can see them from that small pic?
shellbmb
Sep 12, 2014 7:41 PM
saabman
Nov 22, 2009 6:39 AM
larryntripp
Sep 26, 2009 7:28 PM
papak
Colorado
Jun 24, 2008 6:42 PM
