305 tbi timing problems
Old Jun 6, 2010 | 3:51 PM
wayne220's Avatar
Default 305 tbi timing problems
Hi,
First off i will explain what happened and then the after effects..
I just bought the truck and the dash oil pressure gauge was not working. The 305 is rebuilt and cammed. Well i bought a after market pod oil pressure gauge and installed it. To install it i had to pull the distributor out. Well after doing it, i put the distributor back in pointing the same directions it was when i removed it.. Well it jumped timing i guess?
So i then tried to put it back in timing. I do not have a timing light so i removed distributor, belt, #1 spark plug and turned engine by hand to get #1 piston to top dead center. Then pointed distributor to #1. Well i started up, but its no where near how it was running, and sucks the fuel down like crazy now.. misfire, and as a lot of hesitation.
I don't have the extra cash to take it to be fixed in a shop, so I'm hoping you guys might know what I might be doing wrong when timing it the old fashion way, and walk me through how to correct this mistakes i might be making on it.
The truck had almost half a tank of fuel when i first removed distributor, and now is on empty after trying to get it in timing. Also a buddy screwed with the idle screw (he said was the screw that control the air ?) that screw is on the tbi injector where the linkage connects.
I hope thats understandable and some one might be able to help out.
Thanks.
P.S: Truck is a 88 c1500
Old Jun 6, 2010 | 6:15 PM
wayne220's Avatar
Redone the timing stopping a few from top dead center with #1 piston. The misfire etc is all gone, the only problem now is i lost ton's of power and still have slight hesitation at low range.
JoeBobJr
Oct 5, 2011 2:45 PM
mikes86caprice
Mar 2, 2010 9:47 AM
89silverado283
Apr 20, 2009 1:53 AM
smallblocks
Mar 14, 2008 12:10 AM
smallblocks
Mar 13, 2008 10:11 AM
