350, won't start
Old Sep 13, 2015 | 7:27 PM
Fairwind's Avatar
Default 350, won't start
Ok here it is, when I go to start the truck all I get is cranking. I stop and the truck has a rough run on. When I give it more gas it dies. Problem is? The truck is a 1997 Z71, 5.7
Old Sep 16, 2015 | 4:42 PM
96 Junk That Moves's Avatar
Fuel Filter?? Listen for the fuel pump running when you turn on the key. These engines are sensitive to fuel pressure. A clogged filter or a weak fuel pump will cause a no start.
Is it showing a code??
Old Sep 17, 2015 | 1:08 PM
Fairwind's Avatar
Thanks I will check filters and no codes.
Bugfuel
Jan 27, 2015 10:45 AM
Scott Swihart
Feb 23, 2013 11:04 PM
geebo
Nov 19, 2012 8:03 PM
bracca
Jul 12, 2009 6:14 PM
kidster
Mar 22, 2009 11:13 PM
