4 wheel drive advice
on my 1999 silverado the 4 wheel drive system works flawlessly but just the other day the service 4x4 light came on in the dash any direction as to what this may be are greatly appteciated.. 56,000 miles.
i hate to be tellin you this but you could be lookin at a new front dif. have you ever left ur truck in 4 wheel drive while drivin at a high speed. if so then you could be lookin at replacing ur differential. if your lucky though itll mean what mine meant. mine came on a few months ago and all i needed was a new 4wd button panel. these are a lot cheaper than a differential.
sm3earl,
I have a "99" and my service 4x4 light came on and I found the fuse had corrosion on it. Pull out the fuse ,clean the ends off or put in a different fuse in and see if thatcorrects the problem.This fixed mine andthe light hasn't come back in 50K or more.
Good Luck, Dondobe
Good Luck, Dondobe
Do you have push button four wheel drive or on the floor engagement? The push button switch could be bad. Seenthis several times. It could be something as a simple as a blown fuse - check this. I've replaced many front axle acutators and 4 low switches - simple fix and relatively inexpensive. I agree with sm3earl - get it scanned first - this will tell you alot. Tom
olbaldi
June 1st, 2015 2:54 PM
Jaysonic
March 8th, 2010 9:07 PM
