4L60E Filter Change
Old Aug 31, 2009 | 2:05 PM
Yamaharacin's Avatar
Default 4L60E Filter Change
I've been working on this for days now in my 95 K1500
I got the old filter out but that little metal ring is still in the tranny and it doesnt seem to wanna come out. I've taking a pick to it and all and its still in there, and info on how i can get this out?
I dont see anyone else having this problem
Old Aug 31, 2009 | 2:57 PM
I can only speak for the 4L60E on a 1997 Tahoe but I don't recal any metal ring having to come out, the filter should just push back up into the port and be held in by a rubber o-ring....
Old Aug 31, 2009 | 3:09 PM
myotherchevyisablazer's Avatar
x2 for the 700r..if you could get a pic up might be of more help...i think the 4l60 is an updated 700?
dont know if this will help but here ya go http://www.gm-trucks.com/resources/h...-transmission/
Old Aug 31, 2009 | 5:34 PM
Yes the 4l60e is a computerized version of the 700r4 and it is part rubber then part metal for that o ring, the filter and gasket kit comes with a new ring to its better to change it all as you should, i've just tried 2 picks at it and it still doesnt want to come out at all its not even budging
Old Aug 31, 2009 | 6:16 PM
I've seen that post before Blazer and looks like i didnt notice the filing part, dont sound too bad to do but i gotta be careful
Old Aug 31, 2009 | 7:42 PM
MDTAHOE's Avatar
Professional Mechanic
Pry it out carefully with a screw driver. It can be a pain in the a*s
Old Sep 1, 2009 | 10:27 AM
cams 98 silverado's Avatar
you know, when i did mine, it came right out. when i did a customers blazer, same thing. when i did this heavily used truck, it was a 20 minute battle. but finally got it out. now, on transgo's site i have a video on how to install a shift kit and they say if the ring looks in good condition re-use it. same goes for the gaskets. but i never re-use gaskets.
Old Sep 1, 2009 | 10:31 AM
therewolf's Avatar
Yeah, the new, thick gaskets are meant to be re-used. Of course if you want to pay 60$ + for one at a stealership, be my guest.
Old Sep 1, 2009 | 10:41 AM
EvansBlue's Avatar
When I service the trans on my truck, I had to use an ice pick to bend the ring inward and then I pulled it out with a pair of pliers. Its copper it think so it bends fairly easily.
Old Sep 1, 2009 | 7:57 PM
oih82w8's Avatar
I had some clearance (my truck was on a lift), and used a Seal Puller (see attached thumbnail) to remove the o-ring from the old xmsn, and it was still a pain! Take your time and try not to marr (scratch) the side walls or you will lose pressure.
success,
