4l60e help please
Old Aug 25, 2010 | 12:57 PM
vwwebb's Avatar
Default 4l60e help please
I have a 1993 chevy 1500 z71 4x4, i have a crack in my transmission and am trying to find a tranny. What years are compatible with my truck, also is there any way i can buy a two wheel drive tranny and modify the truck to make it work but keep it 4 wheel drive.
Old Aug 25, 2010 | 7:43 PM
maxxman04's Avatar
1st, the only way to make a 2wd trans work in a 4wd is to tear apart the 2wd one and change the output shaft. not a fun job to do, plus requires certain tools and knowledge to do it right. 4l60e's all interchange.
Old Aug 25, 2010 | 8:03 PM
phil737's Avatar
Which Tranny does it have
Old Aug 26, 2010 | 5:42 PM
vwwebb's Avatar
it has a 1993 4l60e off of a 5.7 engine. So all years a re compatible? will switching to a different year have any affect on the computer in the truck. I.E. can i use a 1996 4l60e tranny 4x4? or other years
Old Aug 26, 2010 | 7:52 PM
phil737's Avatar
I wouldnt see why you couldnt, but check to make sure everything lines up before hand and also that it has the same electrical connections just to be safe
Old Aug 26, 2010 | 8:31 PM
gotstylez's Avatar
if yours have he 4x4 shifter in the floor...i think all the 96+ have the electronic 4x4(push button).. i dont think it'll work????? somebody correct me if im wrong..im not 100%
and to be clear im just talking about the 4x4 system here..im sure it will bolt up the same.
Old Aug 27, 2010 | 11:05 PM
tinbender59's Avatar
the 96+ could be ordered with the floor shift, but that is not the issue to worry about, I would check with a wrecking yard for interchange data the only issue you will have is the electronics internal and th plug in. but "don't quote me" but I think they are all the same in all of the "Vortec" trucks. with the exception of clutch packs internal 4.3 = light, 5.7 = heaver, Although I have read somewhere on the net someone has cracked the 4L80E into a 4L60E truck issue. if you PM me your home E-Mail I will send you what files I have copied on the issue
Old Aug 28, 2010 | 2:22 PM
vwwebb's Avatar
nicholas.c.webb@uscg.mil
Old Sep 5, 2010 | 2:11 PM
chris4735's Avatar
hoping someone can help me out i have a 2006 gmc sierra 5.3l 4x4 with a blown tranny can i put a trans out of a 2003 gmc sierr 4.8l 4x4? please help somebody
Old Sep 7, 2010 | 6:29 AM
99ChevyZ71's Avatar
Originally Posted by vwwebb
Not here, geesh.
