4L60E Leak in Reverse Apply Circuit?
![Cool](https://chevroletforum.com/forum/images/icons/icon6.gif)
Hello all, I'm new to the forum and I'm hoping someone can help me out. After doing some research on your forum I think I've narrowed down my problem with my truck.
Symptoms:
Intermittent Reverse, when it's working, it works great. No slippage or anything. Then randomly it will stop working and won't move at all. When it's not working, all forward gears work great.
Through research I've found that no reverse can be due to 3 things: worn clutch packs, reverse apply circuit, or broken sunshell. Because I have my 2 and 4 gears working normally, I assume my sunshell is working properly. A worn clutch pack would mean that over time, the slippage becomes worse and worse, instead of randomly working and not working, which makes me believe it's not clutch pack related. So it leaves me with a leak in the Reverse Apply Circuit.
Would others agree that this is my problem? Or is there something else that I could be missing?
If it is my Reverse Apply Circuit, it looks like I can just drop the valve body and do the repair without completely dropping the tranny. What does everyone suggest?
Thanks in advance!
Symptoms:
Thanks in advance!
Symptoms:
Thanks in advance!
Symptoms:
Thanks in advance!
tonyvisone
11
January 13th, 2014 1:46 PM
bigjlarson
July 20th, 2010 12:22 PM
strongworx
July 28th, 2009 9:26 AM
