4L60E Leak in Reverse Apply Circuit?
Old Jul 11, 2015 | 2:46 PM
XinnKoda's Avatar
Cool 4L60E Leak in Reverse Apply Circuit?
Hello all, I'm new to the forum and I'm hoping someone can help me out. After doing some research on your forum I think I've narrowed down my problem with my truck.
Symptoms:
Intermittent Reverse, when it's working, it works great. No slippage or anything. Then randomly it will stop working and won't move at all. When it's not working, all forward gears work great.
Through research I've found that no reverse can be due to 3 things: worn clutch packs, reverse apply circuit, or broken sunshell. Because I have my 2 and 4 gears working normally, I assume my sunshell is working properly. A worn clutch pack would mean that over time, the slippage becomes worse and worse, instead of randomly working and not working, which makes me believe it's not clutch pack related. So it leaves me with a leak in the Reverse Apply Circuit.
Would others agree that this is my problem? Or is there something else that I could be missing?
If it is my Reverse Apply Circuit, it looks like I can just drop the valve body and do the repair without completely dropping the tranny. What does everyone suggest?
Thanks in advance!
Old Jun 6, 2021 | 11:25 AM
cary perkins's Avatar
Symptoms:
Thanks in advance!
fix? What ended up being your problem? I have same issue, only not intermittent. Reverse just stopped working with so warning or symptoms
ed 1
Aug 26, 2018 1:25 PM
tonyvisone
11
Jan 13, 2014 1:46 PM
BigBlock'Burban
Oct 5, 2011 3:53 AM
bigjlarson
Jul 20, 2010 12:22 PM
strongworx
Jul 28, 2009 9:26 AM
