Notices
4L60E Problem, Can Anyone Help Please!!
Old April 10th, 2008, 11:45 PM
k_grantham10791's Avatar
Default 4L60E Problem, Can Anyone Help Please!!
Dear Fellow Chevy guys and gals,
I need help with a transmission problem. I have a 1996 Chevy 1500 305 vortec with the 4L60E transmission. Well its messed up. If i put it in 1 it works fine, if I put it in 2 it works fine in gear one and two. If I put in in three it shifts from 1 to 2 then it slips and revs up and will not go into 3 or OD, In drive goes through gears one and two fine then slips and will not go higher then 2nd gear. It happneds under light or heavy acceleration. I need some advice on what it could be. The last transmission I tore apart was a chevy 3T40. So any advice would be great. Thanks
Sincerely
Kyle
Old April 10th, 2008, 11:51 PM
Ride of the Month
June 2008
speedy58's Avatar
Default RE: 4L60E Problem, Can Anyone Help Please!!
does rev. work fine with it
Old April 11th, 2008, 12:17 AM
hey whats up, yes reverse works perfectly fine so does d1 and d2. but in d3 and 0d slips..
Old April 11th, 2008, 6:48 AM
jmack91z28's Avatar
I would say that third gear went out in it.
Old April 11th, 2008, 10:21 AM
northey87's Avatar
I agree with jmack91z28, sounds like you lost 3rd gear, time for a rebuild. By the way, welcome to the forum!!!
Old April 11th, 2008, 11:49 AM
Ride of the Month
June 2008
speedy58's Avatar
most deff time for a rebuild or an aftermarket
new one
Old April 11th, 2008, 11:55 AM
thanks guys, add me to msn power_cavy@hotmail.com that would be a quick way to get advice..
Old April 25th, 2008, 3:51 AM
hquick's Avatar
If your signature is anything to go by...forget the 60E and start looking for an 80E. The 60E won't stand up to a 572! (or anything more than a stock 350 for that matter)
Old January 11th, 2014, 10:24 AM
New User
Awaiting E-mail Confirmation
jj0996's Avatar
i agree with that your trannie needs a rebuild but i also sounds like you have a torque converter problem if i were you i would replace that while you are at it
Old January 11th, 2014, 11:08 AM
Dropped95gmc's Avatar
Another thing to try is disconnecting the battery. With it having 1, 2, and rev, it sounds like it may be in fail safe mode. If you disconnect the battery for a few minutes then reconnect and it works well, you may have a solenoid or converter problem causing it to go into fail safe.
Quick Reply: 4L60E Problem, Can Anyone Help Please!!
Top
Follow Us
