4l60E PROBLEMS!
#12
Hi Derek! I've been Dyno testing 4L60E transmissions for a while now and from what you've described it doesn't sound like it's a transmission problem. If you're getting the same thing with 2 different transmissions, I would say the problem lies elsewhere. If you used the same valve body, it wouldn't be a shift solenoid because if you have 1st and 2nd, both solenoids are working properly. The reason why is because 1st gear, both A and B solenoids are on, 2nd is A off and B on. 3rd gear both solenoids are off and 4th is B off and A on. I see a lot of 2-3-2-3 shift patterns when solenoid A has failed. I would check the wiring harness.
Oh and this link is for Allan, anything to help, bro. GM 4L60-E transmission - Wikipedia, the free encyclopedia THIS IS RIGHT FROM GM.
#13
http://en.wikipedia.org/wiki/GM_4L60-E_transmission LOOK AT THAT. I'm happy this will help.
#14
#17
Keep trying ALLEn but I actually know my transmissions and engine work.
This may be a shifter problem?
#19
30 Common 4L60E Transmission Problems & Repair | Charlotte NC Your problem which I hate to say it is the 3-4 clutches are most likely burnt . I just want to put this up for you Derek this is common transmission problems and how to repair them. It goes though anything from the NON SHIFT SOLENOIDS AND ACCUMULATORS ALLAN SEEMS TO NOT REALIZE ARE ON THE 4L60E transmission. It also list other things that if you ever encountered could help you down the road and is a good reference or page to save. I would still not rule out the 2-3 shift solenoid or accumulators. I know for a fact that yes they can cause you from not being able to get into third gear and it can stop you as well. 3-4 clutches being burnt are more or less the area I would look at. Electrically it is possible and I would not rule that out either. Just remember one thing. If your going to go to a mechanic you get what you pay for. They're is no guarantee just because you got a rebuilt or that transmission that is fixed. A remanufactured transmission or new one is a different story. They come with usually 3 year unlimited mileage or 75k mileage warranties as they are fixed right and they want to make sure there is no problem that they are not swapping out the transmission all the time and losing money. Just a little advice from a guy who has worked on transmissions for over 22 years of his life growing up, started at age 8 and went into rebuilding engines around 16 as I always found it a fun, relaxing thing to me. I am not one to rush a job, I rather take my time diagnose every aspect and make sure I know there is no other problems that can happen down the road. Just a little other advice. 80 dollars and you can get a solenoid kit and replace all the solenoids off the valve side as well depending how easy it is to get to each one. Some can be a little harder to get to then others and require removing a lot of extra stuff which goes back to the sun ball location and those you do not want to lose and remember where they go as they can come in 1/4" sizes to 5/8' sizes to etc. Just be careful if you do plan to do it yourself I know a few friends online that have done this before and have full illustrations of totally rebuilding one and could gladly ask them for the links to their page to help you if you do consider fixing or rebuilding the transmission yourself. Just don't rule out wiring till you actually digitally multimeter all the ends and make sure there is no open or shorts. If there isn't, it is your 3-4 clutches that are burnt, there is also a servo that controls the 3-4 as well and a 2-3 shift solenoid which can all play into this so don't overlook any of these. Best thing to do is check one at a time, electrical be easiest, if you can get to the valve side check the 2-3 shift solenoid after as that be an easy check, from there you could look at the 3-4 servo to the 3-4 clutches if they are burnt.
#20
I bought a 97 chevy 1500 4x4, "needed transmission". simple right?
I got a used tranny, put it in and had no shifts and no speedo. bought another tranny, put it in, same problem. Brought truck to local aamco and they notices my VSS wires had come undone, and that fixed my speedo and shifting, so it seems. Now i only have 1st and 2nd, and reverse. 3rd seems like its in neutral or back to 1st gear.
so after aamco told me this, i swapped the tranny again, and still same problem. good 1st, 2nd and reverse. but 3rd feels like neutral. please help me, i would hate to pay for a rebuilt tranny and have to do this a 4th time if not nessessary
Clear all the codes to clear the ECM memory, then drive the truck until the problem occurs. Pull the fresh codes again and report back as to which are set?
Allan
