4L80E to NV4500 conversion
Old Apr 19, 2011 | 9:27 AM
HD6.0's Avatar
Question 4L80E to NV4500 conversion
I have a 2002 2500hd 6.0 with a 4L80E and 147,000 miles. It was my dads truck and has been all over the country, i dont want to sell it. I want to put a NV4500 in it when i get the money. does anyone know how much it will cost and how hard it will be?
Old Apr 19, 2011 | 9:56 PM
tinbender59's Avatar
around here 4500/s go for $1800 to $3000, depending on condition....
and why would you want to get rid of the 4L80E any way? they are way strong, any one that fries an 80 is a total IDIOT. the trans has input and out put sensors for the purpose of detecting slip within the trans. If the ECU senses a slip it reduces the torque to save the trans. Personally I would be looking at a new motor first.
just me!! and I hate sticks with a passion!!!!!
Old Apr 20, 2011 | 8:57 AM
HD6.0's Avatar
well, the thing is theres nothing wrong with it. The truck has 148,000 miles. I just want a manual trans. Ive found on for around 1900, how much would it be to install?
Old Apr 20, 2011 | 10:32 AM
nauticstar87's Avatar
The cost shouldn't be to expensive, the trans will obviously be the most. You'd have to buy a brand new clutch and flywheel. might be aable to go to the junkyard and find all the linkage and the master cylinder. I'd say around 500-1000 on the clutch itself, depending if you want oem or performance. I'd guesstimate about 700 for everthing else. you may need a new driveshaft also. I'm unsure on the length difference of the 4l80 and the NV4500, but im pretty sure the stick is longer...
Old Apr 20, 2011 | 12:32 PM
HD6.0's Avatar
Thanks alot for the good info. I hope i can make it happen perty soon.
Old Oct 12, 2022 | 8:01 AM
Calebs71's Avatar
Did you ever complete this swap? I'm looking to do a similar swap in an 05 Silverado. I've already got a used nv4500 ready to go in I got it from https://reman-transmission.com/trans...s/?code=NV4500
jrsavoie
Jul 27, 2022 1:19 PM
westongc
Mar 31, 2014 7:44 AM
danhiman
Oct 3, 2011 8:04 PM
HD6.0
May 3, 2011 8:52 AM
jrsavoie
Apr 23, 2011 9:22 AM
