4wd issues
Old May 25, 2012 | 9:15 AM
JOSH S.'s Avatar
Default 4wd issues
I need some advice. I recently bought a 1999 Z-71. 5.3 liter V-8. When I first start the truck it will usually shift into 4wd, but after a few minutes the "service 4wd" light comes on and it won't shift anymore. When it does shift, it shifts just fine. I don't know if it's the actuator or switch or something else. Any advice would be greatly appreciated.
Joshua
Old May 27, 2012 | 12:47 PM
JOSH S.'s Avatar
This is my first 4wd so Im having to learn as I go. But if anyone could point me in a direction to start at. I know actuators have caused problems for many people but I don't know much about 4wd systems. Please help.
Old May 28, 2012 | 5:37 AM
johntaps's Avatar
Former Sponsor
Post
Check the fuse and actuator.
Old May 28, 2012 | 7:17 PM
Ryan Brickel's Avatar
i had a 99 gmc 5.3 z71 did the same thing. sometimes it would work until you hit the button then no lights and all of a sudden the service 4wd light came on. went on ebay ordered a switch for 40$ worked perfect after that.
Old May 28, 2012 | 9:42 PM
JOSH S.'s Avatar
The switch was my guess. And its the cheapest on rock auto.com. anyone had any problems ordering from them?
Old Jun 3, 2012 | 11:34 AM
ToooTall1's Avatar
Before spending any money I'd check all the grounds especially the one under driver door on frame. I have three silverado's two with electric shift and one manual. On my 2001 1500 I had to replace the shift modual located behind the instrument panel on the left, Also replace the shift motor on the TX case. Went thru three of them before finding a A-1 cardone rebuilt. The switch was replaced but did no good. As for Rockauto, I use them alot as there prices are good and shipping is fast. Good luck
Old Jun 4, 2012 | 7:53 AM
JOSH S.'s Avatar
thanks for all the input. I greatly appreciate it.
Old Jan 4, 2013 | 8:26 PM
squatedchevy's Avatar
i have a 1997 that started switching back and forth from 2wd to 4wd on it own and now its stuck in 4lo what could be the issue?
Old Jan 5, 2013 | 1:26 PM
Brosebo's Avatar
Default 05 silverado 4wd problems
I am not sure what the actuator is but last weekend I went up to the mountains to play in the snow. I used my 4wd and by the end of the weekend it was acting up. When I start my truck, sometimes it will be in 4 low or hi or the little red light will be on and it always says service 4wd. If its in 4 low or hi I have to turn the truck off and then back on and hope it has shifted out. I have the Z71 model. Any help or suggestions would be appreciated. Thanks
Old Jan 6, 2013 | 12:42 AM
Fishinfooleric10@aol.com's Avatar
For Brosebo it sounds like its the switch on the dash that is giving you problems. I have seen alot of problems like yours solved with replacing the switch the four wheel drive. Also for best results in getting a response, I would start a new thread about your problem rather than jumping in on one
D Chevy
Sep 17, 2012 12:06 PM
04Greg
Mar 2, 2011 9:46 AM
vpbho
Nov 1, 2010 10:08 AM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
