4x4 service light 99 rado
Old Sep 20, 2012 | 1:36 AM
Patricia Garner's Avatar
Default 4x4 service light 99 rado
getting 4x4 service light
i seen online they say its the switch but not going to buy a switch with out knowing for sure
i have a obd2 scanner but cant read tranny codes or am i doing something wrong
truck runs good but always feels like its dragging tanny shifts to all grears
but not sure if its me or truck
oh lol this is my girls name but not redoing post
Old Sep 20, 2012 | 10:03 PM
bump anyone
Old Sep 24, 2012 | 12:16 PM
ToooTall1's Avatar
Have a 2001 Silverado 1500 4x4 with electronic shift. Had problems with 4x4 and ABS when I bought it. I first checked all grounds especially the one under drivers door on frame rail support. Next without the 2k reader from chevy to check codes I replaced the switch, ( chinese crap) didn't work keeped old one installed. Next changed the transfer control motor that is mounted on the tx case. After 3 chinese crap went to a rebuilt and for a short period it worked. Finally I replaced the tx control module located behind the instrument panel left side. Found a used one on E-bay. System has worked for the last 2 years. So my thought is that the module was at fault all along. As for the ABS it was the module located on top of ABS un it on driver side frame. Had to remove whole ABS unit to get to module, sent to a rebuild company back east and it has worked ever since. Good Luck and hope this post may help you
Old Sep 24, 2012 | 1:45 PM
kevinkpk's Avatar
Does it shift or try to shift, can you hear any noise when try to shift? If not, replace the switch, anything not working in the 4x4 will give that service light. I had a switch go bad on my 2000 suburban. Shift solenoids are a known problem.
talamant3z
Mar 13, 2010 11:57 AM
T_D_H
Aug 19, 2009 9:58 PM
rabbit0102030
Colorado
May 8, 2008 3:27 PM
drw0392
Colorado
Sep 20, 2007 12:23 PM
lake
Nov 26, 2005 12:49 AM
