5.0 V8 Stalls
Old Oct 16, 2007 | 11:43 PM
bennyhill007's Avatar
Default 5.0 V8 Stalls
I have a 1991 5.0 V8 TBI, it stalls when I go from Park to Reverse/Drive. If I feather the accelerator into gear, it will run fine. Feels as if the idle is set too low, but I since set the timing to spec.
I since changed the MAP, IAC, spark plugs, EGR, Temp sensor, ECM, TPS, Cap, and Rotor to no avail. My friend has suggested replacing the fuel pump and injectors.
Old Oct 19, 2007 | 5:33 PM
Kevin's Avatar
Default RE: 5.0 V8 Stalls
vacuum leak.
Old Oct 19, 2007 | 5:46 PM
jimmydaleo's Avatar
I agree. get a can of carb cleaner and spray around vacumm hoses until erradic idle happens.
Old Oct 29, 2007 | 8:31 PM
JadedRelics's Avatar
Clean the throttle body if no differance Then look into changeing the injectors ! Those spider packs are famouse for leaking .
Old Sep 29, 2010 | 10:13 PM
warrick's Avatar
I also have a 1991 5.0 V8 TBI, that stalls when I go from Park to Reverse/Drive no matter what i do replaced the torque converter and lock up switch next is the tps hope that works
Jimbo302
Jan 7, 2007 5:21 AM
somery
Oct 27, 2006 11:46 PM
jak1320
Oct 16, 2006 1:32 PM
MYoung
Sep 27, 2006 2:44 PM
bodders
Jul 30, 2006 8:21 PM
