5.7L engine missing!
I have an issue with a 88 K1500 5.7l. I've replaced the fuel pump, fuel pump relay, fuel pressure regulator, fuel injectors, fuel filter, egr valve, egr solenoid, did a complete tune up, replaced the map sensor, tps sensor, ignition coil, ignition control module, idle air control valve, and it's still no better then when I started. It also has a crate motor that was installed about 15,000 miles ago. Any other suggestions?
MSgtBatman
Dec 4, 2009 5:44 PM
