5.7L engine missing!
Old Jan 12, 2012 | 11:32 AM
ekristich's Avatar
Default 5.7L engine missing!
I have an issue with a 88 K1500 5.7l. I've replaced the fuel pump, fuel pump relay, fuel pressure regulator, fuel injectors, fuel filter, egr valve, egr solenoid, did a complete tune up, replaced the map sensor, tps sensor, ignition coil, ignition control module, idle air control valve, and it's still no better then when I started. It also has a crate motor that was installed about 15,000 miles ago. Any other suggestions?
Old Jan 12, 2012 | 12:02 PM
nj85z28's Avatar
Senior Site Administrator
did you try a compression test on each cylinder?
Old Feb 8, 2012 | 12:01 PM
ekristich's Avatar
The problem found with my truck ended up being a bad distributor! Thanks everyone for your ideas!
tylerowen
Astro
Feb 13, 2010 11:20 AM
lazzirus
Jan 1, 2010 2:27 PM
MSgtBatman
Dec 4, 2009 5:44 PM
nealio
Sep 19, 2009 5:29 PM
Makobottomline
Oct 4, 2007 3:33 PM
