5" Rough Country Lift
Old Apr 8, 2014 | 9:54 PM
soldiercat93's Avatar
Default 5" Rough Country Lift
I am buying a 2014 Silverado 1500 z71 4x4. I want to install a suspension lift on it, however I'm not afraid to admit I'm kind of a rookie. So I have a few questions. To begin, I want the truck to sit level (lifted and level) so with the Rough Country 5" suspension lift make it level or will it still have a rake to it? Also will I have to put on new larger tires as soon as its lifted or will the factory work until I buy the new tires? Finally, can anyone post some pictures of Silverados with 5 inch lifts (no real reason, I just want to see how mine compares and maybe get some new ideas).
Old Apr 9, 2014 | 10:31 AM
Fishinfooleric10@aol.com's Avatar
No the lifts are designed so that it sits level and for a 5 inch lift lets just say no you dont need new tires, but your gonna look goofy until you get some big tires. Mine is not lifted 5 inches but if you google you will have plenty.
Old Apr 10, 2014 | 10:43 PM
iluvchevy's Avatar
Adding 5" Rough Country will give you some rake. So if you want to level your truck, get 4" rear blocks.
Old Apr 11, 2014 | 4:25 PM
country_09's Avatar
Rough country supplies blocks with the kit. It'll lift up 5" in front, and should have 3-4" blocks out back to level it out. It's not a very big lift though, probably can run 35s on stock wheels but on anything else 33s max
mrpete
Feb 24, 2014 7:50 PM
chesterz71
Jan 24, 2012 9:31 PM
Acop305
Apr 27, 2011 9:05 AM
tazz
Jul 9, 2008 10:34 AM
biggame
Oct 24, 2007 11:52 PM
