700r4 th350 swap
Old May 13, 2007 | 4:08 PM
An89Chevy's Avatar
Default 700r4 th350 swap
well it not the flexplate. its the 700r4 transmission making the clicking noise. so i have a th350 in a van sitting around that im going to swap into my truck. so if anbody has any experience with swapping a 700r4 transmission with a th350 in a 1989 chevy c1500 2wd shortbed please give me some input.
diffrent yoke?
Diffrent trans mount?
have to move the crossmember?
linkage changes?
i know the th350 is a stronger tranny to run behind a new 350 and with your help i hope to make it a weakend project.
thank you
Phil
Old May 13, 2007 | 7:06 PM
kcb37's Avatar
Default RE: 700r4 th350 swap
If I am correct you should be able to just bolt it up, You will need a longer driveshaft. You may want to check on the crossmember. Other than that i'm pretty sure you don't need anything else.
blacksn
Apr 9, 2014 6:01 PM
chevykid53
Jan 19, 2014 11:54 AM
Ironhead Dave
Chevelle & El Camino
Dec 5, 2010 4:34 PM
sniperx7
Sep 28, 2009 4:10 PM
sulichal
Apr 8, 2008 3:39 AM
