8.1 liter stalling problems
Old Feb 13, 2011 | 12:30 PM
krieger911's Avatar
Default 8.1 liter stalling problems
I have a 2004 Chevy Silverado 2500HD 8.1 liter. At start-up the motor will start, ramp up to an appropriate RPM, then immediately fall on its face and stall. Typically when its cold, it seems to do a little better, but it will still come very close to stalling out. After it has ran for a while and warm it seems to do it more. Anybody have suggestions?
Old Feb 13, 2011 | 1:29 PM
jimmydow1's Avatar
Id be willing to bet it is bad O2 sensors, have them checked.
Old Feb 14, 2011 | 9:20 AM
krieger911's Avatar
Codes show:
B0055-vehicle speed sensor circuit
B0161-torque converter clutch brake switch circuit
U1300-class 2 data link low.
Anybody have any ideas on what could be the problem?
Old Feb 14, 2011 | 10:27 AM
jimmydow1's Avatar
What scanner did you use? My definitions are:
B0055-2nd row center seat belt sensor
B0161-no definition
U1300-class 2 communication circuit high volts class 2 data output link low (suggests a short or bad ground)
B codes are body codes and shouldnt effect the engine operation, but a short or ground issue will/can cause an issue
Old Feb 14, 2011 | 1:26 PM
krieger911's Avatar
Yea...thats what I have been finding. I think the guy told me the wrong definition for the B codes.
The U1300 is the one that I am focusing on. Any ideas on how to track down where the short is? Or make it right.
Old Feb 14, 2011 | 2:31 PM
jimmydow1's Avatar
you can try plugging in your scanner and select diagnostic circuit test, class2 monitor. see if it can "see" all the modules." inactive " read should help you narrow down the affected harness
mudrider
Aug 3, 2022 9:25 PM
slepley
Sep 26, 2014 6:40 PM
Tommygunz
Jul 11, 2007 7:24 PM
wongtahoe
Jan 8, 2007 1:18 AM
Jamespud
Jan 5, 2007 4:56 PM
