89 5.7 TBI
Old Jan 14, 2007 | 9:37 PM
biggs9704's Avatar
Default 89 5.7 TBI
under acceleration, in any gear, it has started to stumble and stall. I changed the cap and rotor, wires, checked the plugs as they only had 8,000 on them, the oxygen-sensor and a new fuel filter. I can still feel the serge and under flat out acceleration it still stumbles. I thought sure it was the oxygen sensor as that is the sourse of most tune-up problems I have had. The motor has 115,000. Any suggestions?
Old Jan 15, 2007 | 11:07 AM
chevyblues's Avatar
Default RE: 89 5.7 TBI
I had a similar problem. Turned out the catalytic converter was blocked enough it was causing problems with the EGR system. Have the EGR checked. If it checks good, then check into the cat. I made the mistake of ordering the high dollar cat that is a direct fit. I ended up at the muffler shop anyway to have them adjust the connection to the headers. A universal fit is much less expensive and just as good. Dynomax sells a high flow cat under the Walker name. I also believe Magnaflow has a high flow cat.
chevyblues
Old Jan 23, 2007 | 2:05 PM
chrisk1500's Avatar
Check fuel psi.....spec is 9-13psi but optimal performance is found at 11-13psi...
Old Feb 4, 2007 | 1:05 PM
Slowrider's Avatar
My 1992 5.7 was doing same thing 2 weeks ago. New plug wires solved my my loss of power. Hope this helps
czarmatra
May 12, 2007 1:16 PM
roman316
Jan 22, 2007 3:05 AM
Aphelion79
Jan 6, 2007 11:16 PM
talltodd1
Oct 9, 2006 12:37 PM
