91 4.3L starts & dies no codes
Old Aug 25, 2010 | 7:56 AM
kinger's Avatar
Default 91 4.3L starts & dies no codes
i have a 91 k1500 4.3l showing no codes 12 flashes constant which to me means no codes present ? will start immed after it dies run for 3-5 seconds then pukes out will run with spraying gas in throttle body 160k on this thing -- fuel pump ? which i can hear running for a sec or two when key is turned on !! wouldnt a ign module act up like this ? and show code ? i am suspecting fuel pump ? am i wrong please help
Old Aug 25, 2010 | 9:30 AM
maxxman04's Avatar
could be ignition mod, coil, fuel pump relay, pump itself. ign mod and coil may not trip a code on the obd1 systems, which your rig has. if it will keep running by spraying down the throttle body, then i suspect the fuel relay or pump. or maybe the oil pressure unit, as this is tied into the ignition system. no oil pressure = no fire.
Old Aug 27, 2010 | 11:37 PM
tinbender59's Avatar
Talking
i'll bet money on sensor real common on OBD1 systems
Old Aug 27, 2010 | 11:51 PM
therewolf's Avatar
Hi kinger,
Welcome to the Chevy Forums.
The Crank Position Sensor doesn't kick up an OBD code...
Old Aug 28, 2010 | 12:01 AM
oil pressure sensor, oil pressure sensor!!!!
Old Sep 2, 2010 | 7:45 PM
kinger's Avatar
it turned out to be fuel pump !!!!!!!!!!!!!!1 thanks
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
billygi4d
Feb 2, 2014 6:50 PM
thisnthat
Nov 20, 2012 11:36 AM
handimanrick
Dec 2, 2006 12:33 PM
