'91 rear differential leak at driveshaft side
Old Aug 25, 2007 | 1:22 PM
keebeaux's Avatar
Default '91 rear differential leak at driveshaft side
Hey all...newbie here.
I tried related posts, but none were the same.
I have a leak from the rear differential of my '91 2wd. It appears to be coming from the front side where the driveshaft connects. I checked my Chilton's for seal R/R info but it only addressed gear replacement.
Can anybody tell me if there is a replacable seal at the input driveshaft end of the diff, if it is a DIYer project and the steps to do so, if possible.
Old Aug 26, 2007 | 8:26 PM
kcb37's Avatar
Default RE: '91 rear differential leak at driveshaft side
You have to take the driveshaft down. Once you have it out you will see a big nut on the yoke. It is something between 1' and 1 1/4' if I remeber right. The easiest way to take that off is with an impact. If you don't have one you may need a cheater pipe. If you can get that off the yoke slides out and you just have to pop out the seal, and put the new one in.
hobhancock
Apr 20, 2012 10:46 PM
DC_443
Dec 2, 2011 3:10 PM
gilbertaarnesson
Astro
Sep 3, 2007 1:55 AM
albinorhino00
Apr 1, 2005 3:20 PM
