93 1500 305 help
Old Aug 22, 2009 | 8:30 PM
crookedpanels's Avatar
Question 93 1500 305 help
Alright guys i have a 1993 1500 with a 305 and it has a mis and an intermittent long crank. Cap, Rotor, plugs, wires have all been replaced. As has the ignition module. I also just did the fuel pump. The mis was there before all of those repairs. What do you guys think it is or suggest to fix/check? The mis is most apparent when cold at idle in gear, through 2000-2500rpm Also, when i drive it on the highway for a while (20 mins) it pretty much completley goes away runs smooth with a slight mis at idle.
Old Aug 22, 2009 | 8:52 PM
lukemoore646's Avatar
try doing a compression test cold
Old Aug 23, 2009 | 9:51 AM
Compression checked out, anyone else have any ideas?
Old Aug 23, 2009 | 10:32 PM
another thought would be to isolate it, run it for a few seconds and see if you can find a cold runner on the exhaust manifold, this is easier with headers
87caprice718
Jul 29, 2015 5:16 PM
natemclain
Aug 4, 2009 10:46 PM
Big_Jazzer
Feb 5, 2009 1:28 PM
Capitanbadass
Feb 27, 2008 7:26 PM
