93 1500 brake light
Old Oct 26, 2012 | 4:15 AM
93z71's Avatar
Default 93 1500 brake light
i am buying a 93 chevy 1500 z71 soon and the brake light comes on once in a while and i'm told its the anti skid thingy. what is the anti skid thing exactly so i know what to order? thanks in advance?
Old Oct 26, 2012 | 6:19 AM
Jeff Collision's Avatar
It is skidding. In your Chevy, on the back of the wheel hub are the wires for the ABS system. The ABS sensor sits on the wheel bearing and hub assembly, and looks like a small rectangular box. Check to make sure all wires are connected and are not damaged. Then, turn the ignition key to the "II" position and check the ABS light. The dash lights will light up initially and should then go out after a few seconds. If the ABS light stays on, then the ABS system has failed. Because the ABS system is secured to the wheel bearings, both units must be changed by a professional mechanic.
Old Oct 26, 2012 | 1:38 PM
93z71's Avatar
ok. so i have to replace what exactly?
Old Oct 27, 2012 | 12:22 AM
93z71's Avatar
Nevermind. Just woke up then and didn't understand. Now I do.
Westontaylor
Sep 16, 2012 8:45 AM
Ralph#82
Aug 31, 2011 3:42 PM
beckya99
Jul 12, 2011 12:29 PM
pabes
Nov 5, 2008 5:30 PM
XCaliGurl
Dec 8, 2007 6:49 PM
