93 1500 cat pronlem
hi guys. i was going on a drive to get a snowmobile when after about 80-90 miles in i pull onto highway and start hearing loud roar from under truck. so i pull over and notice its just when throttle was applied. anywho, i crawled under truck today and a plug or something has broken kinda. will upload pics soon. any things i should watch out for that might be bad in long run and whats the best way to fix this? btw, its a 350 tbi. and it was slushy out so im thinking it was hot then got hit with the slush and caused rapid cooling causing it to crack. any ideas?
I would recommend not driving it till you truly know what that hole leads to. If you do drive on it you risk doing bigger engine damage. Do you know if you got any check engine lights or see any leaks or that? Yes more pictures would greatly help too.
The plug seals the hole where the catalyst beads were loaded from the manufacturing process. With it missing, you have not only a converter that cannot do it's job due to the missing catalyst, but also a LOUD exhaust.
Contrary to some belief, it does not harm the engine in any way to drive it this way, because on a '93 model, this is nothing more than a downstream exhaust issue.
Allan
Allan
only code i have is for knock sensor. but i think my exhaust leak from where manifold meets pip on passenger side. only pic i have, that's the only thing really visable. btw, whats needed to fix that leak by manifold?
Dyoungblood87
Oct 23, 2013 10:43 PM
cambeckkcebmac
Aug 24, 2013 11:06 PM
ericnottelin
Jul 2, 2012 10:03 PM
Seion
Feb 26, 2011 5:03 PM
