93 silverado missing
Old Nov 10, 2012 | 5:02 PM
93z71's Avatar
Default 93 silverado missing
hi guys. finally got my truck. heres the issue. when i test drove it, i felt a shudder and thought tires etc. well turns out it's missing. some times bad, some times just a bit, then sometimes not at all. it even stall out friday morning till she warmed up. thinking dist. or wires,plugs? any other thoughts? it a 93 with a 5.7 with 190 on it.
Old Nov 10, 2012 | 7:31 PM
kevinkpk's Avatar
This is ob1, is the service engine light on?
Old Nov 10, 2012 | 8:02 PM
93z71's Avatar
Ya, I had it tested first. Was map sensor. Replaced and reset. Then after 10 seconds came on and says 43. Electric spark control module failure. Looked under hood and can't find it on firewall by dist.
Old Nov 12, 2012 | 5:07 AM
93z71's Avatar
is it in block case on passenger firewall attached to the pcm? and i know there's one in distributor i was told that's kinda like a u shape. am i correct? i idles ok, but when getting to speed ( above 40) it shakes and surges a little. any ideas? gonna bring it in tomorrow but one place wants $50 to diagnose it.
Old Nov 12, 2012 | 6:27 PM
93z71's Avatar
anyone?
Old Nov 13, 2012 | 5:48 AM
93z71's Avatar
took air cleaner off to look at dist and pulled wire from coil to dist and alot of white powder fell out, thinking corrosion. and inside wire on coil side rusty inside. plus wire had a 1/4" long rub/burn mark in it. any ideas other then that to replace?
Old Nov 19, 2012 | 9:51 PM
oleblue92's Avatar
Sounds like you found it
Old Nov 20, 2012 | 3:26 AM
93z71's Avatar
No. Just tune up. Update Thursday night
Old Nov 20, 2012 | 11:32 PM
oleblue92's Avatar
Good luck!
Old Nov 24, 2012 | 5:19 AM
93z71's Avatar
Turns out it was carbon. On cap/rotor and distributor was loose.
fox48
Apr 8, 2021 7:29 PM
arm&wrench1088
Dec 24, 2010 6:38 AM
deirulz011815
Nov 14, 2010 12:38 PM
rustedduck
Oct 3, 2008 10:45 AM
cube4hire
May 17, 2007 5:10 PM
