94 idle problems when cold
Old Sep 22, 2015 | 2:32 PM
ole dave's Avatar
Default 94 idle problems when cold
Ive got a 94 1500 that cranks fine however it idles good for about 3 seconds at around 700 rpm then the rpms drop. most times the engine will stay running going thru this cycle until it dies. However after if i can keep it running and it reaches 190 degrees and the t stat opens it idles fine. I have replaced water temp sensor, idle air motor, tps, map sensor and O2 sensor. I also installed a new fuel pump with 20psi and 40gph about 2 weeks before this started and a new fuel filter and it worked fine. I can give it gas and it runs fine. Just wont idle when cold. I can unplug the map sensor and it will idle fine. What am I missing. There is nothing else that I know of. Thanks for the help in advance.
Old Sep 22, 2015 | 11:18 PM
Rednucleus's Avatar
my 93 had similar symptoms and needed a new distributor. But only idled rough for less than a minute, then normal after that.
Old Sep 23, 2015 | 11:37 AM
ole dave's Avatar
i also replaced the ignition module and the coil in the distributor
Old Sep 24, 2015 | 8:29 AM
extremeadventurer's Avatar
The issue may be caused by a problem with the idle air control valve.
Old Sep 28, 2015 | 11:26 AM
ole dave's Avatar
Yea I replaced that. No luck
mdec950
May 11, 2012 9:44 PM
Supertwins
Jul 4, 2011 11:39 AM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
Thermool
Jun 20, 2009 6:41 PM
kidunot
Mar 3, 2007 10:52 PM
