94 Silverado Not Running Smooth
Old May 8, 2009 | 10:13 PM
silentj's Avatar
Default 94 Silverado Not Running Smooth
Hey i have a 94 silverado 5.7 and ive noticed in the past week or so that its running kinda rough. When its in drive and im stopped, and then let off the brake the truck shakes if im moving slow, and when i give it some throttle it seems like power is not there the whole time and it shakes a bit as im accelerating. Its like the revs are jumping around a little bit or something. Its really hard to describe but thats basically how it is. I noticed my shifting is just a little bit rougher than it was when i bought the truck and i noticed the shifting problem around the time when the truck started shaking and whatnot. My one guess that im not sure if its right, is that it is my valve body that is worn which is causing this. If anyone has an opinion or can help me out in any way that would be great. Thanks
Old May 9, 2009 | 2:53 AM
new2me's Avatar
When was your last fuel filter change? Check your plug wires to see if they are grounding out.check the coil.Clean the MAF sensor,and throttle body,Check air filter.Check the cap and rotor. Check fuel pressure.
Old May 9, 2009 | 5:17 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I think you're right on suspecting the trans.
Manny559
Jul 7, 2014 6:59 AM
drivelineguy
Jul 27, 2013 10:12 AM
mkylexl
Avalanche
Oct 23, 2007 3:54 PM
aknight_sa
Oct 12, 2007 12:08 AM
