Notices
95 1500 4x4 tyranny fluid leaking truck won't move.
Old February 27th, 2014, 8:53 AM
jbaesl's Avatar
Default 95 1500 4x4 tyranny fluid leaking truck won't move.
Girlfriend was driving it and the truck stop moving when pressing gas. Said tranny fluid was leaking everywhere. What could be the problem?
Old February 27th, 2014, 8:55 AM
'03 Heavy Chevy's Avatar
I'm guessing she ran over something and banged up the transmission.
We need more details.
Old February 27th, 2014, 8:57 AM
Pugly's Avatar
I would have to think the leak is the problem.
Old February 27th, 2014, 9:05 AM
jbaesl's Avatar
What kind of details? Yeah but I can't figure out where it is leaking from.
Old February 27th, 2014, 9:10 AM
jbaesl's Avatar
Looked under hood. A line coming from radiator is broke but I don't where it was going into. Is there a way u can post a picture? Brand new to this forum
Old February 27th, 2014, 9:14 AM
LOL - I was thinking maybe the gf shouldnt be driving his truck anymore.....
You might have to crawl under her (the truck, not your gf) and find if its leaking from the front, side, back of the transmission. Does it look like it has hit something? Is the transmission pan missing? Bolts loose? Etc........
Old February 27th, 2014, 9:18 AM
http://www.justanswer.com/uploads/St..._130218_a1.gif
Like this one?
Old February 27th, 2014, 9:28 AM
Pugly's Avatar
It could be a leak in the pan, cooler lines or the cooler itself.
You might have to add more trans fluid - have you checked the fluid level in the trans?? It appears from your post that there is not enough left in the trans to leak out. I'd add at least 1 gallon of the appropriate ATF fluid. Block all 4 wheels, put the transmission in park, set the parking brake and put the transfer case in neutral to ensure that the truck will not move with the engine running.
Wearing proper eye protection open the hood and start the engine - inspect the cooler lines, connections and cooler for leaking fluid. If none are detected climb under vehicle and inspect the trans pan and cooler lines and connections.
Old February 27th, 2014, 9:38 AM
Looks like we lost him Pugly.......
Old February 27th, 2014, 9:41 AM
Pugly's Avatar
I was only trying to help.
Quick Reply: 95 1500 4x4 tyranny fluid leaking truck won't move.
